Cant get rid of coolant leak! - FirebirdV6.com/CamaroV6.com Message Board
  • Cant get rid of coolant leak!
    I have a 1997 3.8 camaro 5 speed 153,000 miles
    I have replaced the water pump, upper and lower radiator hoses, belt tensioner assembly(broke a seal trying to get it off) little 90 degree plastic coolant elbow. I though the coolant elbow was to blame but it is still leaking rather slowly. I find the coolant collecting on the rack and pinion steering and the bottom front part of the engine. No overheating or anything, probably wouldnt even notice if it wasnt for the smell of coolant when driving.
    Any ideas?
    Thanks.
    Re: Cant get rid of coolant leak!
      Upper intake manifold leak possible??
      No antifreeze in oil..looks fine.
      All problems started when the water pump gave out. I replaced it and flushed the coolant and now I have the coolant problem.
        There are two plastic elbows to replace.
          I only saw one that connects to the belt tensioner assembly and to the intake manifold. Wheres the other one?
