1993 Z28 Fuel Problem - FirebirdV6.com/CamaroV6.com Message Board
  • 1993 Z28 Fuel Problem
    I just traded for a 93 z28 and i am having a problem. The car will run for about 5 seconds and then dies. I was wondering if it is the fuel pump or is the a fuse or module that could be bad. I would appericate an help possible.Thanks
    can u give it gas and keep it goin or does it die after 5 seconds no matter what?
    1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
      replace the fuel filter.
        it dies no matter what. But you never hear the fuel pump running.
          sigh....
          Lt1s have a serious problem with the fuel gauges. they are typically off by a little to,like mine,about a quarter tank off. make sure it has gas in it.
          can you hear the fuel pump priming when you turn the key? go to autozone and get a fuel pressure gauge(like 15bucks at the most) and hook it up to the fuel rail. i cant remember the exact psi but it should be around 40psi or so.
          im telling you right now, stop trying to start it. i did that and now im paying out the a$$ for it becuase i didnt know any better. i fouled out 3 injectors by sucking up dirt deposits from the bottom of the tank and had to get them replaced and have the fuel lines pulled out and blown out.
          if its the fuel pump it will cost around 220 for a stocker. and its a bytch to get to(dropping suspension,exhaust,and fueltank)
          check these things out and let me know what you got going on. ill try and help as much as i can.
          Follow me!
          Or this
            shoot me an email also and ill try to help ya that way also.
            Follow me!
            Or this
