i have a 98 firebird manual tht has a broken trans mount and im trying to buy one but do i need the hydraulic or solid one? and also which brand im looking at auto zone ? can someone please help me
Need help choosing a trans mount
Re: Need help choosing a trans mount
Go with a poly mount Prothane or whatever you can find ($20)and it will never break again, add poly spacers or rubber ones to correct the driveshaft height and your set. I ran mine in my M5 and A4 had no problems.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
what he said...
only problem is they dont make a specific mount for our cars so you have to get the universal one. They stock them on the shelf at autozone for like $25.
But because they are universal, you have to cut a little slot in the cross member (takes like 10 min with a dremel)
Then what i did was use 2 sway bar end link bushings as spacers so that the vibrations arent near as bad because of the stiffness of the poly mount
well i went to ayutozone and they have a couple some which are hydraulic and some tht are solid with fdiffrent brands? which one?
these are my options
http://www.autozone.com/autozone/cat...xt=trans+mount
Originally posted by robert View Postwell i went to ayutozone and they have a couple some which are hydraulic and some tht are solid with fdiffrent brands? which one?
i found this writeup that might help you with your decision: http://www.turbofirebird.com/Default.aspx?tabid=75
yeah but if i go with a hydraulic mount would i have to do any mods to put back up to stock hieght or is tht just witht the solid mounts which require fabrication? and if i did go with a hydraulic would i still need tyo use bushing to raise the trans regular hieght?
Originally posted by robert View Postyeah but if i go with a hydraulic mount would i have to do any mods to put back up to stock hieght or is tht just witht the solid mounts which require fabrication? and if i did go with a hydraulic would i still need tyo use bushing to raise the trans regular hieght?
Originally posted by silVerSIXf-body View Postthats a really good idea. i was half way though my install of a poly mount and i had to stop because i noticed the heights of the two mounts are different and didnt have any clue on what to do to fix that. so by added the sway bar bushings you kept the stock height? any vibrations at higher speeds?
Originally posted by cam98aro View Postlike i said in your other thread, if you dont want to go with a hydraulic mount, you will have to modify your car
