Is there a way to replace the TPS sensor on a 99 camaro that has fly-by-wire?
TPS sensor replacement on a 99?
Re: TPS sensor replacement on a 99?
no, you need a new tb. usually the tb doesn't go bad. i had this problem and removed the maf, cleaned it, put it back in and it went awayCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
