have a question - FirebirdV6.com/CamaroV6.com Message Board
have a question
  • have a question
    my ac does not blow towards me it on comes out to the windshield and feet i was wondering if its this
    http://cgi.ebay.com/ebaymotors/93-02...Q5fAccessories
    and if it is where is it located?
    Re: have a question
    crank the car, and turn the ac on. turn the car off, and move the switches around, you should hear some sounds, like air moving around, and flaps closing. if you dont then, remove your switch panel and make sure its all connected. if so then your problem is either a bad vacuum line, or that piece. where its located on our cars, i have no idea.
    Team NoVa
      Re: have a question
      where would the vacuum line be located?
        Re: have a question
        i know on the ls1's it is behind the intake manifold.. so i would assume its somewhere around there on the 6's also
          Re: have a question
          there will be one that goes from the map sensor on the passenger side of the intake to where ever.
          Team NoVa
            Re: have a question
            ill look for it but my arms too fat and its tight back there but ill poke around to see if i find it
              Re: have a question
              here.
              the line coming from that goes to the map sensor and then around the intake to a vac port on the fuel rail. check to see if any of that is broken. thats where it gets vac from.
              Team NoVa
                Re: have a question
                and if its not broke?
                  Re: have a question
                  One piece at a time we'll try to diagnose it.
                  My car has started doing this too. During long trips I find that the air flow considerably lessens with the AC on until you shut it off and reset it. It also has started cutting out when accelerating at higher rpms, typically redirecting the air to upper parts of the dash, most likely the windshield defrost vents and floor vents. I'm wondering if left alone, it would end up similar to yours; constantly blowing toward the windshield and floor.
                  '99 Camaro
                  '04 Saab 9-3 Aero
                  '90 Audi Coupe Quattro
