well i was driving back from work today when all of a sudden my check gauges light came on all were fine. car started decellerating slowly but the engine was still running. shifted down to try to get something going and it still continued to decellerate. so i shut if off tried to start it back up and got nothing didnt wanna crank over. tried popping the clutch nothing. any suggestions please help car in need of assisstance.
car died!!!!!!!!!
yeah sounds like your fuel pump went kablooey.. (that's a technical term by the way) easy way to check have a buddy lie down by the tank and you turn the key to the "ON" position listen for it coming on. no noise no pump, check the fuse before dropping the tank though just in case-Brad
2000 V-Star Custom 1100
:rock:
I have the same problem on my 99 auto. It's been randomly stalling for the past month, all the times it has been while driving. I can hear the fuel pump turn on when I start the car, what else could it be? I took it to a mechanic and he said I had a few plugs corroded and a fan belt on its way out...anyone else with any ideas?SOLD - 1999 Black Firebird<br />A4, T-tops, 3.42 gears, Y87 Package<br />[Appearance mods] Chrome side vents, Pontiac metallic silver rear inlay<br />[Performance mods] TSP Rumbler<br /> <a href=\"http://www.cardomain.com/id/eminemz115\" target=\"_blank\">PICS</a>
fuel PSI reulator, ummm dont knowwww.turbov6camaro.com
1997 3800 Series II Camaro
