Leaking coolant - FirebirdV6.com/CamaroV6.com Message Board
Leaking coolant
  • Leaking coolant
    Yesterday, I put my car on the lift to lube up the axles and suspension component and liquid was dropping from the k-member. I smelled it and it smells like coolant. It is dripping alot and I need to get it fixed. The coolant it all over the passenger side of the k-member and it leaks so much that it will form a puddle if I have the car parked.
    I cant find out where the leak is coming from. Anyone have any idea? I checked all the hoses in front of the engine to but couldnt find any leak. Its not near the radiator. Its not the thermostat houseing. I have no idea where it is from.
    Anyone have any clue where the leak is coming from? I'm hoping its a hose or something easy to fix.
    1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
    I can almost guarantee you right now its your water pump. Check the weep hole and see if the area around the water pump is wet. I had the same exact problem, put a new water pump in and no more leaks.
    1996 Pontiac Firebird: A4, Flowmaster 80 Series, dual 3\" Stainless Steel tips, SLP CAI, Alpine CDA-9813 deck, Infinity speakers, Alpine Type R sub, MTX Thunder 801d amp, Tsunami 2 Farad Capacitor.<br /> <a href=\"http://www.cardomain.com/id/firebirdfury\" target=\"_blank\">http://www.cardomain.com/id/firebirdfury</a>
      I had the same problem about 6 months ago on my bird and it turns out i was leaking coolant from the water pump, you might wanna get that checked out. Ever since then she's been running great.
