Where do you bleed the slave cylinder at ? - FirebirdV6.com/CamaroV6.com Message Board
  • Where do you bleed the slave cylinder at ?
    Ok I need to bleed my clutch and I dont have a mighty vac or anyway to get one. So I was going to bleed it at the slave cylinder. I jacked the car up and got up under there but I looked and didn't really know where to bleed the clutch at. Can anyone give me a detailed explanation or a pic of where the bleeder screw is ?
    Thanks
    Re: Where do you bleed the slave cylinder at ?
    First of all, this should be in the drivetrain section.
    Second, If you opened the drivetrain section, there is a sticky at the top on HOW TO bleed the clutch system.
    Third, the bleeder valve sticks out the driver side of the bellhousing. it sticks out a few inches.
    *Matt
      http://forum.camarov6.com/showthread.php?t=93221
      http://forum.camarov6.com/showthread.php?t=76855
      *Matt
        Bottom part sticks out the bellhousing, just below where the hose goes in.
        Also, it is not required to use a vacuum bleeder or hand pump to bleed it, but it sometimes helps.
        *Matt
