Taylor Spiro Pro 8mm wires - FirebirdV6.com/CamaroV6.com Message Board
  • Taylor Spiro Pro 8mm wires
    i dont know if this should go under this section but it is in the mod encyclopedia so here it is. i cant find the wires that the mod encylopedia is talking about at the site it gives me anyone know where they are exactly
    thanks
    <a href=\"http://www.cardomain.com/ride/2151539/1\" target=\"_blank\">http://www.cardomain.com/ride/2151539/1</a>
    this is the wrong section but I got mine at thunderracing.com
    1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
      were they easy to install?
        also it says at thunderracing that it only goes up to 99 and mine is an 02. will it still work?
          thanks for movin it i wasnt sure where it was supposed to go
            O im not sure if it will fit, cause I got mine specifically for a 3.4 but I dont know they should have kits for each car. I dont know about the install cause I had someone do it with my tuneup which cost me $150 just for the labor. I will never do that again.
              Does anyone know where i can some blue wires for my 02?
