ripped out that damn air silencer.... - FirebirdV6.com/CamaroV6.com Message Board
  • ripped out that damn air silencer....
    ...and replaced it with some high-temp ducting. i drilled a hole in the airbox so the IAT sensor could go into it, and secured it with some rubber grommets. i also took some silicone sealant, cuz the hole i drilled was a little too big for the sensor, and filled in the spaces. not bad, took me like 20 minutes to a 1/2 hour to do, most of that was screwing and unscrewing the clamps on the hoses.
    i took a lil test drive, and i was very surprised. pulls harder, and it sounds awesome! there was a HUGE difference in sound, both deeper and louder. i was actually laughing as i drove it cuz i liked the way it sounded. i used 4" ducting, perfect fit over the TB. I have like 18 feet of the ducting left, so if 9 people wanna do this, i'll send you 2 feet of ducting and some grommets to hold the IAT sensor. just email me about it, and i'll try and set something up.
    \'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
    18 feet :eek: talk about over kill
    2000 3.8 A4 Pewter Camaro
      well, the ducting only came in 20-foot sections...it wasn't like i could buy only the 2 feet that i used. i figure some other people will wanna try it, so i can just sell the materials and step-by-step instructions. not a bad way of using the remaining stuff.
        I got mine in a 10' section.
          I sent you an email about getting a section of that ducting. I found 10' section too but it was $60 [img]graemlins/omg.gif[/img]
          <a href=\"http://www.cardomain.com/id/ukwildcats00\" target=\"_blank\">http://www.cardomain.com/id/ukwildcats00</a> <br />Mods are on the site.
            10' = $60?! jesus h. christ, where did you find that? mine was waaaaay cheaper than that.
            edit: i sent you an email back, 'cuda. there might be more than one of them, my computer was acting up when i sent it.
            [ July 06, 2004, 12:07 AM: Message edited by: skorpion317 ]
              yeah, i used a 3" pvc cupling on mine, deffinate difference in throttle response and more intake noise (but in a good way). ive had it on for about a year now with no melting or any other problems.
                Hey, I have heard about this mod and I am very interested. I do have some questions though. Did you remove everything between the airlid and the TB? Also, did you you have to bend the tubing to get it to fit onto the oval shaped airbox lid output in the back? And what did you use to clamp it onto the the TB and lid? If you could answer these questions I would be very interested in some of your tubing.
                1998 Camaro- Billet grille, Clear corners, T/A take-off muffler, 5%tint
                  well i used the stock rubber flex tubes so i could keep the sensor mounted in the stock location and have less work to do. then i just forced the 3" cupling into the oval rubber on the one side and then into the other side (its easeir to do this if you take the airbox lid and the rubber tubing, from both sides of the silencer, off the car and put the pvc inbetween it and then reinstall it all). then just use hose clamps to tighten the rubber to the pvc. its really easy, took me like 5 minutes.
                    the pre-'99 cars can't do this, because the throttle body is at an angle. the PVC won't work. everything from the airbox to the TB must be removed and tossed.
                    Bunz, i had to bend the airbox side of the ducting to get it to fit on the airbox opening. not very hard to do. i bought some pipe clamps (they screw on and off) to hold the ducting onto the airbox and TB. i'll throw in two of these with the ducting, grommets, and instructions, for those who are interested.
                      I definitely want you to send me the kit you described above. How much will this cost me? Also, will you take a money order? You can email me the details at cbuns55@yahoo.com I appreciate it man.
                        I'm interested e mail me at Jacob@ferrell-law.com
                        1996 Metalic Bule Camaro: no cat BORLA muffler 245-50-16 falken 502\'s descreened MAF 1pc driveshaft<br /><br /><br />soon to come: fixing that dagum Quarter Panel that i jacked up.<br /><br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a> &lt;----CO-FOUNDER<br /><br /><a href=\"http://www.dahleinsurance.com\" target=\"_blank\">NEED INSURANCE?</a>
                          yeah your right, i forgot the 98 still had the old andgled TB.
