FYI: 97-98 ZZP Throttle Body does not fit. - FirebirdV6.com/CamaroV6.com Message Board
  • FYI: 97-98 ZZP Throttle Body does not fit.
    I just received mine, and I'm gonna have to send it back. It is quite different from ours. There is no way that it's gonna mate to our intake plenum. Design is completely different. Called ZZP and talked to a representative, and he said that it was the only one that they carried. I will admit that the work on the throttle body is quite good. Shipping was fast, and they even included a new MAF screen and ring if I needed it.
    Too bad we can't use it.
    <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
    Which TB did you order? There are two.
    Raven
      Forgot all about this post. I ordered the GT High Velocity throttle body. The one advertised (still) to fit our cars. Talked to a tech once I got mine, and he said that the one I had was what they carried for my car. The throttlebody I received looks just like the one pictured on the website. They did send my money back with an apology.
