I have a A4 94 Camaro. I already have the 80 Series Flowmaster which sounds great. I'm going to put on a high flow cat, I also want to put on bigger pipes. Which should I get, Y or I pipes? I'm going to get them 3 inches. Do you have any idea how much it would cost?
I or Y pipe?
just get the y-pipe matched to the collector diameter on your headers, then have the 2 sides connect to a 3" collector and go into a 3"cat and 3" I-pipe.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
<blockquote>quote:</font><hr>Originally posted by Patrick Javert:
just get the y-pipe matched to the collector diameter on your headers, then have the 2 sides connect to a 3" collector and go into a 3"cat and 3" I-pipe.<hr></blockquote>
:rolleyes: Disregard that.
A Y-pipe and an I-pipe are two very different things. The Y-pipe is what runs from your exhaust manifolds to your catalytic converter, and the I-pipe is what runs between your cat and your muffler.
No point it getting a new Y-pipe if you don't have headers.
If you want a new I-pipe, you can order the 3" pieces shortdog listed, or buy a used 2.75" piece off of a V8 Camaro or Firebird. Dynomax is supposed to have a 2.5" mandrel bent piece, but availability seems to be in question at the moment.-James<br /><br />\'96 3.8L A4 Camaro (SOLD)
say i got a new set of pacesetter headers, would the y pipe off an LT1 help me any?
also, whats this talk of an S pipe? i wanna upgrade to 2.75" diameter piping!Black 1995 3.4L V6 \"<b>THE BLACKBIRD</b>\"<br /><b>Performance Mods </b> K&N Fipk, Hypertech Underdrive pullies, Accell Coilpacks, and wires, rapidfire plugs,180 degree thermo, 1LE Tranny Mount, Z28 Catback W/crome tips B&M Ripper shifter<p><b>Appearance mods</b> 2 1/2% Limo tint all around, Blacked out taillights, turn signals, and side markers, red PONTIAC rear Inlay, 98+ style centerplate bird and graphic<p><b>Stereo System</b>Panasonic Cqdf 800u head unit, 2 MTX thunder 280 amps bridged, 2 Cerwin Vega AI 12\'s on the rear deck, 6x9\'s in the rear sail panels, Monsoon Door panels With Memphis Audio 6.5\" Coaxials and tweeters, 1 farad EFX cap.
While on the topic of Y pipes, Has anybody compared one on a 2000 to that of a 94 V6 camaro? Mine on my 94 was strait pipe except for the gashes where the lady that had it before me ran over stuff. Mine now is kinda crimped or something weird, looks like an intestine or something. Does this hurt the flow enough to worry?
I just replaced my S pipe so let me explain a little and hopefully yours is like mine but no garantees. The manifolds go into a Y pipe which is calls so because it takes two 2" pipes(Maybe bigger, I forget) and combines it to a 3" pipe. Then it goes into the cat and then out as a 2 1/4" pipe. FYI I'm stating inside diameters not outside ones. Then after the cat there is a S pipe, two 90* bends making a S form because there is about a 9 1/2" offset of were the pipe is and were it needs to be because of how the car is formed and where there is room to run the pipe. Then the I pipe, Intermidiate pipe runs from there back to the muffler.
I don't know about the LT1 Y pipe but I have all 3" pipe now and I love the top end, all except the noise. It gets really loud and annoying but sounds awsome at idle and up to 2,500rpm. That's now were I try to shift unless I need to get somewhere quick or I'm racing. Plenty of low end still, that's all I can use without being annoyingly loud.1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
<blockquote>quote:</font><hr>Originally posted by Reg Kmet:
say i got a new set of pacesetter headers, would the y pipe off an LT1 help me any?<hr></blockquote> No. They're different sizes. I believe I've heard that the 3.4 Pacesetter headers come with a Y-pipe.
<blockquote>quote:</font><hr>also, whats this talk of an S pipe? i wanna upgrade to 2.75" diameter piping!<hr></blockquote>The "S-pipe" is what we call the S-shaped bend in the exhaust after the catalytic converter and just before going up over the axle. You're going to be hard-pressed to find 2.75" piping unless you pull the exhaust system off an old LT1 car. Otherwise, stick to either 2.5" or 3".-James<br /><br />\'96 3.8L A4 Camaro (SOLD)
<blockquote>quote:</font><hr>Originally posted by Ttop34:
Mine now is kinda crimped or something weird, looks like an intestine or something. Does this hurt the flow enough to worry?<hr></blockquote>
It's fine. [img]graemlins/thumbsup.gif[/img]
That's just another "quality" GM product. :rolleyes:-James<br /><br />\'96 3.8L A4 Camaro (SOLD)
