Ok...I can't figure out why I am not shifting at 5700rpms where I want it to...instead the trans is going to 5850rpm and bouncing off the limiter... why?
I know two conditions must be met in order for it to shift...both those conditions are present...why is it not going...
I can't get my log or tune to stick up here for some reason, so anyone that can help please pm me and I will email you both my scan and my tune
Change your 1-2,2-3,3,4 back to stock , the computer calculates these settings once you do your tire and gear. Then set your WOT shifts to your 5700, and your fuel cutoff at 5800 rpms. This is why I never messed with the 1-2,2-3,3-4 mph setups, just top RPMS at 6000.
