steering wheel stiff when turning - FirebirdV6.com/CamaroV6.com Message Board
  • steering wheel stiff when turning
    so today my steering wheel felt stiff when i turn. It was fine at first then it just got stiff all of a sudden and its not my power steering fluid because i checked it already. idk if this matters but the steering wheel turns itself back to its normal position after i turn. idk what could be wrong any input would be helpful. thanks
    Re: steering wheel stiff when turning
    Any noise? if not probably bad seal in the rack & pinion would be my guess.
      the power steering pump may be on its way out
      did it only do it one time, or is it doing it all of the time now?
      also, every car i have ever driven had te steering wheel go back to its normal position after i turn, and that includes cars from the 60's, 80's, 90's and 00's all with power steering.
        it does it all the time now...every turn i make is stiff
          I think I may be having this same issue, how much does it cost to replace the power steering pump?
            Its about $100 after you return your core after taking the pulley off. Plus power steering fluid, and should be able to rent a pulley puller for free if you don't have one. but usually the pump will have a small leak in the rear or make alot of noise.
              i was doing donuts in the snow and i turned the steering wheel all the way to the right while doing the donut and when i tried to turn it to the left it was stiff all of a sudden.
                yup you burnt your pump up alot of people burn them up during some fun 360s
                2001 Camaro 3.8 A4
                1991 3000GT VR4
                2001 Mitsubishi Eclipse GS
                  so your almost a %100 that its the pump? thanks
                    i am 100% it happens to alot of people when they decide to do donuts
                    2001 Camaro 3.8 A4
                    1991 3000GT VR4
                      This is why I don't do donuts and burnouts and whatnot, I had the same power steering pump for 160,000 + miles, just finally replaced it last year and replaced my R&P 3 weeks ago , do to the factory alm. piece inside wearing out and the rag joint wearing out(replaced with LS1 style coupler) and FE2 R&P. Cars will last along time if well taken care of and not abused(much anyways), I used Royal Purple power steering fluid after the old fluid was flushed out so I hope to get another 160,000 miles out of my new pump and FE2 R&P.
                        yea im done playing around with my car like that i hate when these things happen so i think i finally learned my lesson before something worse happens like a blown engine...thanks guys now all i have to do is order it offline and replace....ummm can anyone tell me how to replace the power steering pump?
                          2 bolts that hold the pump on which you get to by going through the pulley holes, take off pulley and hoses. Install pulley on new or rebuilt pump and put bolts hoses back on, bleed system by turning the steering wheel left to right or let set over night and top off fluid and your done. Take old pump back for core refund.
                            sounds simple enough its just freezing and i hope it doesnt snow the day i decide to work on it lol
                              pump came in today going to wait till tomorrow to install. Anyone know what size socket i need to get the old bolts and pump out?
