Breaks and Rotors - FirebirdV6.com/CamaroV6.com Message Board
Breaks and Rotors
  • Breaks and Rotors
    Just a few questions... Ive been thinkin about trying to change my own breaks and rotors because it looks easy. First what all tools would I need to do the job so that i'll know... Hex wrench size ect.... And I think my rotors are heat warped. I had the pads changed not to long ago. Would I have to change the pads as well or do you think they would be okay?
    Re: Breaks and Rotors
    What year is the car? The LT1 calipers use a 3/8" Allen wrench. The LS1 brakes use a regular bolt, 13mm or 15mm I believe, don't remember. This is talking in terms of the front brakes, which I assume you're talking about because rear rotors generally don't warp.
    Usually they will resurface your rotors when you change the pads, they generally say you shouldn't change the pads without resurfacing or getting new rotors, but that can be argued. I personally would change the pads as well to remove doubt and avoid any future problems, as well as increase the interval until you have to do it again anyway.
    And it's "brakes," not "breaks."
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      I would def. use new pads on new rotors just so they break in the rotor right plus most companies will tell you too when breaking in the rotor. Ceramic pads I think are the best , Hawks, Satisfied or Duralast some excellent brands, rotors R1 concepts I have had good luck with D/S and also Powerslot slotted rotors. Next time I 'm trying Bremo Blanks or just slotted all around. The drilled I think takes away some stopping power. I noticed a difference with the power slots on the front just slotted.
