Help! I'm becoming frustrated with my attempt to install new sway bars! I have a 98 and everything seems to be nice and rusty... I had to cut off the endlinks because they were not budging at all. But now I'm trying to remove the brackets that hold the D bushings in place, and I've gone through 2 13mm ratchet heads without any movement at all. Does anyone have any tricks to getting these off aside from cutting through them as well? I dont have replacements at the moment...Thanks.
Swaybar Help!!!
Swaybar Help!!!
1998 3.8 Navy Blue Camaro, lowered, Flowmaster exhaust, headers, Whisper lid, free ram air mod, Jet stage II chip, complete Alpine system, numerous appearance mods.<br /><br /><a href=\"http://www.cardomain.com/ride/774091/1\" target=\"_blank\">My CarDomain Site</a>Tags: None
Use a wire brush to clear off all the rust and oxidation.
Then soak with PB Blaster. This stuff works so much better than WD40. Shoot it every half hour for a couple hours, and it should come loose.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
Yeah, I soaked mine with that PB Blaster, but I ended up breaking one bolt that holds the bushing bracket on. I just drilled it out and re-tapped it. Took an extra hour to finish, but it worked great. Them bolts were rusty...bigtime!!sigpic
A little fire never hurts [img]smile.gif[/img]1999 Pontiac Trans Am M6 Far from stock.....
Remember to try to clean and soak the top side of the bolts if you can..Drivetrain Moderator - "There are no stupid questions, only stupid people!"
Go Sabres!
Multiple soaks with PB, and a breaker bar w/ a 13mm 1/2 socket, would do it nicely.<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
