1LE Panhard - FirebirdV6.com/CamaroV6.com Message Board
1LE Panhard
  • 1LE Panhard
    Hi,
    i have a question, i ordered the 1LE Panhard 10262147, but it is not available anymore.
    They were made until 1999, but the 2002 SS Camaro or 2002 WS6 Firebird do they have also a stiffer panhard ?
    do they have an other partnumber, or is it the stock one, like the V6 and Z28 ?
    It maybe stupid questions, but it is difficult to get parts with correct partnumber here in the Netherlands.
    I have a 1993-2002 part catalog (PDF-file), and this catalog has only two partnumbers for the panhard, the stock one (i already have on my car) and the 1LE one.
    Re: 1LE Panhard
    The only thing different is the stiffness of the rubber bushings.
    Best replacement are ES poly bushings. I have the 1LE and am replacing the old bushings with the ES.
    Raven
      Re: 1LE Panhard
      i have read a lot about the Camaro suspension (mostly on this site), when you replace the rubber bushings with poly ones, don't you get the "binding" problem ?
      That's the main reason, i didn't buy a panhard from UMI
      Has anyone ever tried the panhard MOOG K6341, they look the same as orginal
        Re: 1LE Panhard
        I dont see why you woulf get binding on the panhard bar. There is a little side to side movement but not super neccessary. I think an F body would be fine to run all polys on.
        An A or G body on the other hand with the 4 link it is advised you run polys on the bottoms and rubber on one end of the upper arms. Theres different geometries going on bewteen a 4 link and torque arm F body style.
          Re: 1LE Panhard
          "Suspension Bind" affects the LCA only - not the PHR. The Moog are OEM replacements, but again, the ES is the best for the PHR.
          Raven
            Re: 1LE Panhard
            Thanks for the advice
            Has anybody some experience with the "Roto joints" from UMI , what's the quality of this part ?
