Front Bushings Size, help please. - FirebirdV6.com/CamaroV6.com Message Board
  • Front Bushings Size, help please.
    I bought 30 mm front bar bushings from E-Bay for my OEM front bar 99. The seller says that 30 mm fits camaros 93-02. But when I put them to the bar they fit loose, not as tight as the old originals. Do you think that tightening the clamps going to fit OK?
    Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
    Re: Front Bushings Size, help please.
    Need to tighten the endlinks and the front clamps to see if it is loose.
      I just got this from the technical database section:
      Front stabilizer bar
      93-97 30mm
      98-01 28mm
      Have anybody tried 30 on 99 OEM bar?
        The issue here is that the old bushings fit very tight and the new urethanes (prothane) fit very loose. I checked the Prothane site and they don't have less than 28. Only 30 and 32. They have 30 as OEM.
          30mm is Oem for v8 cars 93-02 and 93-97 v6, not 98-02 v6 so the 30mm is not going to fit your 28 mm bar.
            OK. Do you know if there're polyurethene bushings available for 28 mm? I can't find on e-bay.
              yes look through energy suspension they will have 28mm bushing.
                OK. Thank you guys.
                  Rule of thumb - NEVER trust the aftermarket. Do your own reseach - why we created the Tech Database.
                  When they say "OEM" they are taking about a V8 car. They don't care about, nor know anything about, the differences on a V6 car.
                  Raven
                    They don't have urethanes on 18mm. I can't believe I can't find them.
                      What do you need 18mm for?
                        I need polyurethane bushings for 18 mm OEM sway bar.
                          Where do you have a 18mm bar?
                          Fronts are 28, 30, 32mm
                          Rears are 15, 17, 19mm
                          Raven
                            Sorry, I meaned 28mm.
                              That was hard - took 3 minutes.
                              http://www.energysuspensionparts.com...sp?prod=9.5130
                              Raven
