knoi vs. kyb - FirebirdV6.com/CamaroV6.com Message Board
knoi vs. kyb
  • knoi vs. kyb
    Koni Special Single Adjustable or the KYB AGX Adjustable what is the better shock for the money and performance
    1998 green camaro, bear rotors.<br />It\'s not how much money you have, It\'s how many toys you have.
    There is no comparison between the two. If you're going to spend the money on KYBs, get Bilsteins. If you're going to need more than a Bilstein, get the Koni. Its very simple ;)
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      hey,
      i heard that the koni's are overpriced and not worth it, a buddy of mine with a 02-Z reccomended the kyb gr-2 i think, theyre silver, or does koni make them? is anyone running these?
      later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
        I'm running KYB AGX's right now. The Blisteins or Konis would be better.
        ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
          I have the KYBs. They're okay, but the softest settings (1) is not even close to how I would want them at the race track. I think that they would be excellent for road racing and such for the price. Not a bad shock, but not ready for the drag strip. I'll be honest with you, though. I think that you will get similar results at the drag strip with any multi-purpose shock. If you want a drag shock, then get a drag shock with the correct ratio. Gonna suck in everyday driving, though. Don't take any hard curves with them. :D
          Hope this helps.
          <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
            Basicly.. if you have the money.. koni's are realllllllly nice shocks if you know how to set them up for your application..
            I like the HD's personaly.. cause you can get teh valved for your specific application, and then you are set..
            I have heard mixed opinions on the kyb's.. they are "OK".. but if you want adjustability the koni's are the way to go..
            ~Bill
              ok so the the kyb's are not the best so how are the Bilstein and/or slp Bilstein vs. the koni's
