Where to get wheel spacers?? - FirebirdV6.com/CamaroV6.com Message Board
  • Where to get wheel spacers??
    i mounted 265/40/18 drag radials on the back..and on one side the tire is just BARELY rubbing..i think its only over a bump..can i get a spacer for my car to push the rim out a little..and if so..where should i get one??..thanks!
    if at all possible, i would avoid using spacers...it moves the wheel out farther and puts more stress on the studs
    1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
      When I got custom wheels on my other car I had to get spacers too. Most places that sell wheels will have them, mine were only like five or six dollars a piece. I have never heard of it putting stress on the studs though. I am not saying you are wrong but why do you say that?
      1999 Firebird
        This is what I have
        http://www.stockcarproducts.com/wheels2.htm
        1999 Firebird
          what 94' Firebird said ^^^ Also, at the track they may not pass you in tech if your studs do not protrude to the outside of the wheels. I had this problem with my front skinnies that I had to use spacers with. It is possible that under high speeds, the wheel could come off because the lugs aren't grabbing enough of the stud. As for buying the spacers, you could call Summit and just try them to see if it works. You might be taking a chance though... and it could be a costly one, so be careful.
          2004 CE Corvette 10.86@132mph
          2011 Cadillac CTS-V
          2006 Mitsubishi Eclipse GS
            hmmm...i'll call summit and see what the deal is..thanks!
              If the tire is barely rubbing, you can get buy with a thin spacer, which won't bother the studs much.
              The bigger the spacer, the more stress on the studs.
              - Justin
              <a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
                yeah its barely rubbing..there are all different sizes..1/16, 1/8, 1/4..what should i go with?
