Can the rear disk brakes be adjusted? I pulled the E-Brake, and the rear disk brakes are hardly grabbing. Is it an adjustment from the E-Brake handle?
Also, should I switch to a Master Cylinder designed for 4 wheel disks? I now have the one for front disk, rear drum.
The E-brake is controlling drum brakes inside the disc rotor. The disc brakes in the rear are only controlled by the floor pedal via hydraulics. Some cars have "Drum in disc" E-brakes, others don't - our cars happen to be this way though.
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
