need help picking out new brakes - FirebirdV6.com/CamaroV6.com Message Board
  • need help picking out new brakes
    hey guys i am fed up with this damn brake squeal so i have decided to go ahead and replace all four. i want somethin that is not stock , its seems like many people either have slotted or cross drilled or both rotors. what is the best thing to go with and also what pads should i get ? ceramic pads? any help would be great
    2000 firebird w68, auto, t-tops , 3.42 , k&n, whisper lid, taylor 8mm spark plug wires , bosch spark plugs , 3\"in/out carsound CAT , 3\" i pipe, take off trans am muffler, C6 Z06 rims
    also what brands of rotors and pads u recommend?
      If you have the money go for the Baer Eradispeed rotors....they won't crack if you break them in right. If you don't get semi-metallic pads if you want your brakes to be quiet.
        how much did the rotors cost u and what kind of pads did you go with? did you have any problem with them since u put them on?
          2000 firebird.
          www.tirerack.com
          Brembo replacement front rotors
          Hawk HPS pads
          Rears are likely fine, replace them if you think you need to. Check the rotors and pads for wear before replacing. If you need them, get them. Try fixing just the fronts first.
          While your at it, get the brake system flushed whether you or a shop does it. Go with a good DOT4 or 5.1 fluid too. :cool:
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
            <blockquote>quote:</font><hr>Originally posted by Dominic:
            While your at it, get the brake system flushed whether you or a shop does it. Go with a good DOT4 or 5.1 fluid too. :cool: <hr></blockquote>
            Why DOT 4 or 5.1 when the recommended is DOT3?
            What is the difference? Do 4 or 5.1 resist heating better or what?
            Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
