I'm wanting to get a set of cross-drilled rotors for my car for nice looks as well as the good stoping performance. I'm considering Power Stops cross-drilled rotors. Others are too expensive for me right now. My buddy is aldo considering gettin these type of rotors. However, he told em that he was told that cross-drilled rotors have tendancy to crack and break. I'm hoping this is not true. i'm wanting to find this out for both of us. Also are the Power Stop rotors good or not. Thanx guys!!!
Cross-drille rotors????
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Tags: None
A cheeper line is the powerstop. yes cross drilling does tend to weeken the rotor. Look for a sloted or dimpled rotor if your worried about that. Zinc coating is something else to think about. If you want some really sweet rotors look for the baer epi-speed (sp) rotors. Expensive but really nice. If they made them for the LT1 I would get some for my car :(1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
The Powerslot Pro rotors and dimpled and slotted. They would probably be your best bet.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
tirerack.com has a lot of rotors that you can search by vehicle and compare.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
I recommend against cross-drilled unless you like the look. They do not "perform" better.2002 5-spd NBM Camaro
Details: www.1lev6.com
I like the look of the Cross-Drilled, and realize that there's no perfomance gain in them over slotted. They do crack from what I hear.
So where do you all stand on dimpled/slotted (not drilled all the way through)for the looks, but still get the gains of the slotted?~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
i love my cross/drill/sloted for looks and stoping they dont heat up as much and break fade is no longer there like it use to bewww.turbov6camaro.com
1997 3800 Series II Camaro
You are not going to hve to worry about cracking unless you plan on autocrossing on a regular basis. Just be gentle when first breaking them in, and be sure to get a good set of pads.2000 Sebring Silver Z28 M6<br />Jet-hot lt\'s,!cats, Hooker aerochamber,slp cai,mti lid, slp ss hood-spoiler-cme,eibach springs,bmr control arms & relo. brackets,bmr adj. phb,slp sfc\'s & stb,b&m ripper,Z06 wheels, Nitto 555\'s, and much more
