My rear passenger tire is a lil too big and I need to pound out a lil bit of the wheel well. My tire only rubs when I make a turn. Any pointers on how I should go about doing this? I know it won't be too hard but still, I dont wanna screw up.
18" too big
what is with this, 18" is suppose to fit and i always hear stories of it rubbing.
how does your rear passenger tire only rub when you make a turn..
why should it matter whether you are turning or not with the rear tire?2000 Bright Red Camaro 3800 V6, A4, LSD, 3.42<br />Whisper lid, K&N, American Thunder Catback, Wings West GFX, Billet Grill<br /><br /> <a href=\"http://www.mfba.org\" target=\"_blank\">http://www.mfba.org</a> <br /> <a href=\"http://home.comcast.net/~thontor/camaro/\" target=\"_blank\">http://home.comcast.net/~thontor/camaro/</a>
Get a better panhard rod. Get an adjustable one to make sure the wheels are centered side to side, and either poly or rod ends to keep the bushings from deflecting as much in corners.
Problem will be solved.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
