LS1 brake conversion... - FirebirdV6.com/CamaroV6.com Message Board
  • LS1 brake conversion...
    i was in the middle of doing my coversion to my camaro when i was taking off the lower A-arm. i hit the bottom of the knuckle to loosen in but when i went to take the rest of the castle nut off, the bolt turned with the nut, i didn't know how to get if off. i could greatly use any help asap
    also, does anyone know what part of the brake line needs to be bent forward.
    [ April 01, 2002: Message edited by: bustacap54 ]</p>
    Nick<br /><br />1996 White RS
    Couple of thoughts.
    1. Impact wrench.
    2. If you don't have any load on the bolt, temporarily put a load on it long enough to get the nut broken loose. Sometimes as little as wedging a screwdriver in there somewhere. Maybe setting the rotor against a wooden block and letting the car down just a little against it.
      There will be a metal brake line coming into the wheel well and it goes into a bracket and then adapts to the rubber line. That bracket where the two lines meet you will want to bend down a little to like a 45 degree angle. Maybe a little less.
      This is also a good time to replace ball joints while you are under there. Just fyi
      Hot Cammed LT1 Sleeper
        <blockquote>quote:</font><hr> This is also a good time to replace ball joints while you are under there. <hr></blockquote>
        how exactly is this done, becuase aren't they pressed in?
        [img]graemlins/dunce.gif[/img]
          Upper ones you have to drill out the 3 rivets. Lower ones you have to get pressed in.
