So I just replaced all the rotors and pads on my car because I had some warped rotors. Now when I'm braking the brake pedal pumps up and down while i'm applying a constant pressure with my foot. The pedal acually moves my foot up and down while braking. Called around and Brake Depot said they think it might be a bad rotor. I already topped off the brake fluid. Any ideas on what this might be? Thanks in advance
New Pads N Rotors, Now Pedal pumps up n down while braking
What do you mean by "moving your foot up-n-down"?
If it's pulsating quickly, then it sounds like a warped or bad rotor. If it's moving your foot slowly up-n-down, it may be your antilock system or master cylinder.
Try bleeding the brakes first. It may not be your answer, but it'll save you time and money if it is.sigpic
Turns out it was warped rotors right out of the box. Sucks that new rotors can be warped. Anyways got it fixed, thanks for the help.2000 Y87 Bird M5 with mods<p><a href=\"http://www.vzavenue.net/~ngeorg/\" target=\"_blank\">http://www.vzavenue.net/~ngeorg/</a>
Originally posted by chas:
be sure to use a torque wrench when installing your lugnuts and install the lugnuts in a star pattern. its very easy to warp the rotors with improper tightening.Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
mine has done that the past 2 brake jobs that my mechanic (works for Bendix brake company) has put on, so i dont know it cant be anytyhing defective because he woulda caught it.99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
