<blockquote>quote:</font><hr>Originally posted by LordoftheBling: need some sway bar advice and where to purchase the recommended pieces <hr></blockquote>
32 (or 35) front.
19 (or 21) rear.
The '93 1LE front (32 hollow) and rear (21 solid) bars are pretty reasonably priced, and available through several sources including the board sponsors.
Some people say a 21 rear is too big though. (stock is 17.) The 21 is a bit stiff for cornering, and it would be considered small for drag racing.
A 35 solid front is quite a bit heavier than a 32 hollow front, if you are thinking of drag racing, the weight is a consideration. I think road racers prefer the 35, especially in the v8 cars.
[ September 19, 2003: Message edited by: John_D. ]</p>
The Eibach springs are stiffer, and the shocks are also "stiffer" too. Both of these will control roll a lot over stock. If that isn't enough, go with a 32mm front and 19mm rear bar.
Its hard to recommend anything for you if I dont know what you do with the car.
Front bar options are:
28mm
30mm
32mm
35mm
Rear bar options are:
15mm
17mm
19mm
21mm
25mm
21mm bar in the rear is most certainly *as stiff* as I'd ever go. I'd swap between 32/35 bars up front depending on the course or duty... likely going with a 32 up front for street duty.
