Had a little accident.. where i smacked against a curb.. initially i thought i could replace the wheel and tire and everything would be fine....then came the metal on metal grinding.. a genius said i needed new rotors and pads.. then the genius had to bend my dust shield.. through all that i still have the metal on metal sound.. went to a local franchise brake shop and they are saying my rear end is out of line and its causing my front to be out of line.
