I am looking at getting a set of 18in wheels and I have a few questions. Anyone know anything about ADR wheels???? What is the best size of tire to get??? A friend of mine suggested 245/40-18 but I'm not sure. Thanks for the help.
Anyone with 18's come on in!!
As long as you get the correct offset for the WIDTH of the wheel, the HEIGHT is fine. As for tires, the WS6/SS/Firehawk come with 275/40's, but hey are on 17" wheels. If you want to go 18" the correct tire size is 275/35/18, this way the wheel/tire combo won't throw off your speedo.
I'm going with 18's and 245/40 rubber in the front and 275/35 rubber in the back. I'm going with narrower rubber on the front, because the turn-in is better.
Any other questions, just ask.
-Andrew
BTW, this is a good site for the questions you are asking:
http://members.aol.com/camaro1997v6/wheels.html
[ March 05, 2003: Message edited by: BattyV6 ]</p>1998 NBM Pontiac Firebird - LS1/T56 Swap | Pro-Kit Springs & Bilstein HD\'s | BMR LCA\'s | LG Adj. PHR | T-top Conversion | <br /> <a href=\"http://members.cardomain.com/battyv6\" target=\"_blank\">http://members.cardomain.com/battyv6</a>
never heard of ADR. I wouldn't go any bigger than the wheels than 275/35 on back and front. 275 on the front will rub slightly on hard turns. Thye will also rub going slowly or at a stop. But it isent bad at all.Factory:Camaro 5 speed, Color Pewter, w/ t-tops and Y87 package. <br />Engine: K&N filter w/ Whisper Lid, FRA, Borla adjustable cat-back exhaust. Hurst w/ Short Stick<br />Interior:Oil temp. and Air/Fuel ratio gauges, System.<br />Exterior: Black outs front and back, 18 in. Lenso rims w/ Kumho Supra 275/35ZR18 tires, also limo tint on sides and back.<br />173.2rwhp-----200.5tq
This is a link to the ADR wheels. What do you guys think?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=678298 Camaro 3.8<br />Whisper Lid w/ K&N<br />FTRA<br />Halo Black Headlights<br />Hurst Shifter
Go for 'em, they're purdy!!!
-Andrew1998 NBM Pontiac Firebird - LS1/T56 Swap | Pro-Kit Springs & Bilstein HD\'s | BMR LCA\'s | LG Adj. PHR | T-top Conversion | <br /> <a href=\"http://members.cardomain.com/battyv6\" target=\"_blank\">http://members.cardomain.com/battyv6</a>
Nice rims, I like them.
I have 245/50 on all 4...<b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
Those are very nice wheels, and a nice price too!
If I may make a suggestion, if you want them, just buy them, don't bid. I recently stole some 16x8 torque thrust IIs that way for 680 dollars shipped. If I didn't have those coming to me, I would snatch these from under you.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
My rims are 18x9 and I use 275/35-18 tires. They have the same outer diameter as the stock wheels. They look great too.97 Silver Camaro M5<br />Y87 Package<br />K&N FIPK<br />Flowmaster 80 Series<br />Mille Miglia MM11-2 18x9 wheels<br />Kumho ECSTA 275/35ZR 18s<br />Centerforce Dual Friction<br />B&M Ripper Shifter<br />1LE Aluminum DS<br />BMR LCA\'S<br />SLP 1.8 Rockers<br />ZZP UD WP Pulley<br />H&R Sport Springs<br />Spohn Adj PHR<br />160* Thermostat
What is the 120 all about, isnt our wheel set up 5 on 4.75 and 114.3, not 120?99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
Those are the rims I've been thinking about.
these too:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33748
or these
http://cgi.ebay.com/ebaymotors/ws/eB...category=33748<b>Black 1996 Firebird</b><br /><b>Newest Edition: Harlan Window Switch</b><br />Nitrous Express Kit,ASCD big block hood, SLP Loudmouth, CATCO hi-flow cat, CAI, -Maf, LSD, Flameball Shifter<br /><b>Best N/A 1/4 in</b> 15.216 @ 89.82 <b>Best N2O 1/4 in</b> 14.352 @ 97.46 <--w/clutch slippage<br /><a href=\"http://www.geocities.com/motorhead69/\" target=\"_blank\">My homepage</a><br /><b>AIM:</b>MotorHead75068 <b>YIM:</b>MotorHead69
17x7 is narrower than your stock wheel. If you go with a 17" wheel you should at least get something 9" or wider.2002 5-spd NBM Camaro
Details: www.1lev6.com
