installed umi lca's - FirebirdV6.com/CamaroV6.com Message Board
installed umi lca's
  • installed umi lca's
    http://photobucket.com/albums/b249/x...ontrol%20arms/
    install was a breeze, bolts werent too rusty, the car has only been through one winter so it wasn't so bad, i hosed everything down with penetraiting oil before i started. took it for a test drive, def. better hook up, i think the bushings in my old ones were a little whooped so my ride is a bit smoother as well. Well worth the $, and it's an easy install with new hardware.
    1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
    they do make a nice difference. i also agree well worth the money. they a good place to start modding the suspension too.
      WAWA-A-HOLIC
        Oh, and there is very little wheel hop, next mod, aside from exhaust is a torque arm.
          torque arm is one of the next one on my list too. you might want to look into a phr too to finish up the rear. if it not lowered just get a non-adjustable one, if it is id go with an adjustable one.
            i'm going to keep it stock height, so i can get the non adjustable suspension parts. A phr is a good idea, what do you think about the bmr panhard relocation kit that thunder racing sells, is it worth the money, to compliment a phr, or should i just stick with a phr?
              The only reason I know of for getting a panhard relocation kit, is so people can run trueduals over the driverside. The BMR piece allows more clearance.
              the black 97 <br /> New favorite Mods: Hptuners, and SLP 2OTL
                SFC al also good from what i hear, the stiff the car up nice and good and also a noticable difference.
                I have most of my suspention parts but no time to install them, so ill just put them on all at once
                -Paul-<br /><br />03 Lancer Evolution VIII<br /><br />1998 Camaro M5 - Traded
                  1 day ago
                • Doodler
                  97 Camaro base with expensive sounding noises
                  by Doodler
                  Still trying to find oil leak
