New z06 rims - FirebirdV6.com/CamaroV6.com Message Board
New z06 rims
  • New z06 rims
    I just bought some z06 replica rims off ebay rims
    17s in front and 18s in back. for tire size i was thinking 245s and 275s that should fit right?
    <a href=\"http://www.cardomain.com/ride/802975/3\" target=\"_blank\">http://www.cardomain.com/ride/802975/3</a>
    our stockers can fit 245
    if you dont mind me asking, why did you get two different size wheels? are you planning of never rotating those expensive tires? make sure when you have those tires installed, that they dont put wheel weights on the oustide lip, called static balancing. those weights will tear them up real good otherwise ;)
    2000 3.8 A4 Pewter Camaro
      yeah i am not looking forward to buying 2 different sets of tires. but it should look preatty cool. how will the weights tear up the rims?
        if the person balancing them doesnt bother do proper measuring and install them properly, those things can take off finishes easily.
          ok thanks ill keep that in mind. but i shouldnt have a hard time having 275s in the back right?
            no id go 285 or 295 give it a drag look. I have ZR1 SS wheels with 275s and fit fine but then i put in spacers and has a really bada$$ stance. go for wider tires and spacer. My Rims are 9.5 so 295 should be great. IF u want ill look at what is on my dads vette.
            Read my liscenceplate Frame Corvettenet.com<br /><br />2000 Y87 Pewter A4<br />MODS:Tuned,3.73, SLP CAI, K&N offroad aircharger intake,Custom Plexi-glass Ram Air Box, Red Caliper ,Stage 2 Jet PCM, 3 inch Borla XR-1 Catback,ZR1 Rims Kuhmo 712s,MSD 8.5 SC wires
              ok i think i am going to go with 245/40/17 in the front and 285/35/18 in the back. i think am going to go with Sumitomo HTR Z II from tirerack.com from what ive heard i shouldnt have a problem fitting them in. also is 245s going to be wide enough on 9.5s? i dont what them too wide in the front but i want them to fit. should be placing order for tires tomarrow mabe.
              Thanks
              ill be sure to post pics of rims when i get them on.
                pics of car now.
                  im runnin
                  265/40/17 Front 17x9.5
                  295/35/18 Rear 18x10.5
                  came out good i think
                  2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
