Will that fit on a 95' Camaro ?
Rims -18x7.5 40mm offset ???
What is the bolt pattern size? This will need to be 5-lug, 4 3/4" (4.75) bolt circle.
You may have problems with a 40mm offset sticking out too far and rubbing the upper lip of the wheel well when the suspension is compressed. But being only a 7.5" wide wheel it should be okay.
The stock wheels are 16x8 with 50mm offset.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
