Just starting to mod suspension - FirebirdV6.com/CamaroV6.com Message Board
  • Just starting to mod suspension
    Does anyone have any links or advice on suspension mods for someone just starting to work on it. I need basic info on what is best to begin with and what different mods will do for me.
    Thanks a lot for any help.
    1999 Firebird
    Depends on what you want. Drag or road racing or perhaps a little of each?
    \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
      Well what sparked my interest was when I read a post in the drag forum about upgrading this type of thing and not so much adding power mods. In particular, something about Little G, and I see he is running mid 13's.
      I'm not expecting to run 13's just with suspension work, but that is kind of my question.
      What things can I do to compliment my other upgrades? I guess to answer your question, drag is probably more what I would work on.
      1999 Firebird
        lower control arms and a panhard bar designed for drag would be a good start.
        Visit My F-Body Page
          LCA's are a good place to start and there cheap(around $100 bucks). panhard isnt going to make a whole lot of difference in drag, but is better for handling. then a torque arm. lca's and a torque arm are a very good combo for the track.
            well, panhard might help a bit with wheel hop, and its a cheaper alternative to the torque arm.
              Also LCA brakets even if you are not lowered, you might lower it later anyway. I would do Brackets, Box LCA's and A panhard bar to start, then some SFC's.
                1st thing you should do or anybody should do is get a set of subframe connectors.. I have the weld on macs.. They were 119.00.. Best suspension mod I have ever done.. after that LCA's, TQ arm, Springs, and shocks, then a PHB..
                Jeff ..
                1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
                2002 WS6 T/A.. Bolt ins..448rwhp
                2009 G8 GT.. Vararam intake, GXP axleback
                1998 Corvette.. Vararam intake, Ti axleback
                http://www.fquick.com/slow-v6
                  I read that LCA's make the car pretty noisy. I dont have any wheel hop or anything, so would it still be worth it?
                  1999 Firebird
                    What makes them noise is the poly bushings.. I would start out with subframes and see if you need any more parts from there..
                    Jeff ..
                      a panhard is prolly the last thing I would do to a drag car. All the panhard does is keep the rear from moving left and right. It does nothing for straight line traction.
                      LCAs and relo brackets, shocks, torque arm, front k-member & a-arms, sfc's
                      That's the order I would choose.
                      - Justin
                      <a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
