32mm front swaybar is awesome - FirebirdV6.com/CamaroV6.com Message Board
  • 32mm front swaybar is awesome
    ive been riding around with the stock swaybar and bushings/endlinks for a while now, with a broken bushing mount no less, and just figured thats how the car handled. slightly boaty in hard turns, tons of roll, etc.
    so i wanted to hopefully get rid of that somewhat. replaced the broken bracket and installed a 1le 32mm sway with red energy suspension poly bushings and endlinks.
    huge difference. my car corners flat as hell now.
    so my suspension is as follows:
    eibach prokit
    slp/bilstein shocks
    ss wheels
    275/40/17 kumho ecsta asx tires
    32mm 1le front sway with poly bushings
    everything else stock. im thinking ill just stick with the 17mm rear bar for now. im thinking the next thing i really need are lca relocation brackets. im having an awfully easy time spinning my 275s with my little 3.4l.
    <a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
    Re: 32mm front swaybar is awesome
    No need to relocate the rear LCA's... you just need stickier tires.
    <a href=\"http://www.cardomain.com/id/vracer111\" target=\"_blank\">My \'98 Camaro</a><br /><br /><a href=\"http://www.honda-tech.com/garage?cmd=viewcar&id=1223\" target=\"_blank\">My \'98 Tacoma</a>
