I have seen a few shots of people doing C4 rear end swaps into fbodies for an independant rear end. I havn't had any luck finding any info beyond a few bad pictures. Anyone here tried it, or looked into the work required?
Anyone ever do a indepedant rear end?
Re: Anyone ever do a indepedant rear end?
Originally posted by UDLOSE98someone did a 4th gen. with indep. rear. I have seen the pics, it might have even been in the lounge.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Originally posted by loseri dont remember where it was either, i think it was a lt1. looked VERY nice. ill try to find it.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Insane new level of performance? The only things that will improve with an Independent Rear Suspension is decreased sensitivity to bumps on the surface (the independant part of IRS) and not so much rear self-steering from toe-out as the body rolls when cornering. IRS adds weight, more parasitic driveline drag loss, and has no real handling advantage over a live axle on a smooth road/track surface other than the ability to adjust camber and toe. Then again with a live axle, the rear wheels always stay perpendicular to the ground throughout the entire suspension travel, not leaning inside-to-outside throughout the suspension travel like with an IRS.
Independent rear suspension is more of a "cool" factor than a major performance handling improvement. The live axle design of a 4th generation F-body is all about handling and performance to begin with.Last edited by Vracer111; 08-21-2006, 03:26 PM.<a href=\"http://www.cardomain.com/id/vracer111\" target=\"_blank\">My \'98 Camaro</a><br /><br /><a href=\"http://www.honda-tech.com/garage?cmd=viewcar&id=1223\" target=\"_blank\">My \'98 Tacoma</a>
Originally posted by Vracer111Insane new level of performance? The only things that will improve with an Independent Rear Suspension is decreased sensitivity to bumps on the surface (the independant part of IRS) and not so much rear self-steering from toe-out as the body rolls when cornering. IRS adds weight, more parasitic driveline drag loss, and has no real handling advantage over a live axle on a smooth road/track surface other than the ability to adjust camber and toe. Then again with a live axle, the rear wheels always stay perpendicular to the ground throughout the entire suspension travel, not leaning inside-to-outside throughout the suspension travel like with an IRS.
Independent rear suspension is more of a "cool" factor than a major performance handling improvement. The live axle design of a 4th generation F-body is all about handling and performance to begin with.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
VRacer111 has some good points, but it's not the whole deal. The decrease in "unsprung weight" is substantial and will allow the wheels to follow the road better. It's the reason why, in every pavement race series where it's allowed (like, not NASCAR) race cars use independent rear suspension. People have long tried to incorporate live axle virtues into a better suspension. For example, the DeDion, frame moounted the diff to reduce unsprung weight. None has succeeded.
The real joker is chassis design. The fbody chassis was designed to accept certain suspension loads at certain places. Somehow tack a Corvette rear on and the chassis will be stressed in new ways. It may (probably will) flex.
Car design is a complex thing. You can't change just one thing and expect great results. An independent rear fbody would be a poser thing, not a performance mod.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
Originally posted by V6BobThe real joker is chassis design. The fbody chassis was designed to accept certain suspension loads at certain places. Somehow tack a Corvette rear on and the chassis will be stressed in new ways. It may (probably will) flex.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
