98+ brake upgrade - FirebirdV6.com/CamaroV6.com Message Board
98+ brake upgrade
  • 98+ brake upgrade
    Well soon ill b buyin everythin i need to upgrade my LT1 style brakes to the LS1 style...i know the rotors r bigger and all but will they fit in my salad shooters?
    87 Firebird RIP
    96 Camaro RS RIP
    94 Patriot Red 1LE Z28 - Sold
    02 WS6 TA - Sold
    Re: 98+ brake upgrade
    yes they will. they fit in the stock 16" trans am wheels so they will fit your stock 16" salad shooters.
    i am doing the same thing within the next month...goodluck!
    1995 Firebird 3.4 V6 M5<br />-Firehawk 17x9 w/275/40/ZR17, flowmaster 80s, high-flow cat<br />*new* BMR lowering springs, Bilstein shocks, WS.6 sway bars, polyurethane bushings.
      You will have a problem with the brake lines. Both don't fit properly. I had custom Goodridge G-Stop Stainless Steel Braided Brake Hoses made. Special part number 12217-SPL. (317) 244-1000
      Raven
        doesnt the kit from tacreations comin with the needed brake lines?
        87 Firebird RIP
        96 Camaro RS RIP
        02 WS6 TA - Sold
          Factory rubber - which do not fit properly. The body attachment point is different on the 93-97 and 98+ cars.
          This is a well documented problem.
          Raven
            thanks for the heads up
            87 Firebird RIP
            96 Camaro RS RIP
            02 WS6 TA - Sold
              I have a 98+ rear disk brake axle(non-TCS) going in as well as front 98+ brakes(knuckles, calipers, rotors, hubs, etc).
              I'm working on powder-coating the calipers and caliper brakets now.
              I have all of the brake hoses that came with the 98+ brakes, but will they not work with my 94 car? There shouldn't be a problem with the rear brakes. That center rear hose is the same part number from pre '98 to post '98. But you guys are saying that you can't used the 98+ front hoses on a pre-98 car? Is the connection point where the hardline transitions to the rubber line different? The new hose will be too short or too long? What's the solution? Use the original hoses in the front?
              Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
                YES
                Neither the 93-97 or 98+ will work properly.
                I have custom made front hoses Goodridge G-Stop p/n 12217-SPL from http://www.goodridge.net/
                Raven
                  Long ago you said that the attachment point just has to be moved down some:
                  http://forum.camarov6.com/showthread.php?t=12885
                  Is this not a viable option?
                  How much were those custom lines?
