anybody put there fbody on air I have a friend that can hook me up for like 500 with every thing i need. Just curious about handling and ride improvments.
Air Ride
Re: Air Ride
If an Fbody rode as well as my Lincoln MkVIII does with it, 500 would be worth it if you tour alot.
There is alot of room in an Fbody bumper and nose for a compressor, unlike the MkVIII. Moisture in it and the lines is the challenge...
Re: Air Ride
It's a lot of work and I doubt the cost will actually come out to 500ish after it's all said and done but if so Air ride suspesions are great. They can go from a smooth ride to a corner carver at the flip of a switch. The only real downfall is it weighs a lot more than a traditional system. Good luck if you go with it. I will be of little help to you though and I doubt many others on here will either since it's such a rare thing to find on our cars. You might want to go to a truck board or something for more info on setting one up propperly if your friend can't do everything for you.
John.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
