Has Anyone added posi-trac to their v6 camaros? Is a complete rear axle conversion necessay? How hard is that conversion and how much? Drums belong in a band.... :P
Posi-Trac on a 3.4 95 Camaro???
Re: Posi-Trac on a 3.4 95 Camaro???
if u wanna add posi to ur rear end im pretty sure u can, but it will cost alot of money for the LSD and the installation for it. You would be better off getting a used rear end with posi tractions already there, and with probably better gearing for acceration. (z28 or Y87)
Becuase if you were planning on keeping ur gears for your posi. Then your lsd wont be to useful, unless u have alot of power behind the wheels. If i were you i would get 3.42's or 3.73's with posi rear end.
