LCA brackets - FirebirdV6.com/CamaroV6.com Message Board
LCA brackets
  • LCA brackets
    I will be installing a set of LCA brackets on the car soon. I purchased them for 60 bucks off of LS1tech.com and they look like new. Should I put them in the lowest setting of the bracket when installing? I have the Hotchkis 1in drop kit if you need to know wih Bilsteins all around.
    01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
    www.vaperz.com
    Re: LCA brackets
    start with the lowest. but you can switch back and forth to see which one you like better.
      Re: LCA brackets
      I agree the lowest should be right where you need your LCA's to be.
        Re: LCA brackets
        If you put the relocation brackets on car can you use stock LCA? Or do you need to get aftermarket that are adjustable? When I put rearend back together I'm going to have same setup as Firehawk.
        Originally posted by kala
        TEAM BLACK!!!
        parting her out
          Re: LCA brackets
          they work with stock or aftermarket lcas just fine.
          As for the bolt hole, go with the lowest setting
          http://www.bowtiev6.com/
            Re: LCA brackets
            Thats what I thougth guys, but wasnt sure. Thanx a lot. I have a post in the Advanced section so check that out and see if any of you can help me there as well.
            www.vaperz.com
