Stock LCA bushings - FirebirdV6.com/CamaroV6.com Message Board
Stock LCA bushings
  • Stock LCA bushings
    What is the best place online for stock LCA bushings?
    Thanks
    Keith
    Re: Stock LCA bushings
    why would you wanna buy stock when you can get poly inserts
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
      Don't go poly, do Moog, there is plenty of threads on why not to use poly bushings on lcas, binding is not good.
      Why not go to a local autoparts store? I think they are like 8 bucks for a set of stock ones, and 30ish for Moog.
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        The local parts stores around here don't have them and I do not want poly. This is a daily driver and stock will be more than enough.
        Thanks
        Keith
          The Moog will be similar to the 1LE bushing. And poly bushings are fine in the STOCK LCA, not in an aftermarket tubular.
          Raven
            ^^ that is correct, my bad. The moog will be fine for a daily driver, but if you insist on stock soft rubber, an autoparts store should be able to order them in the least.
              Well you talked me into it, I ordered the MOOG bushings.
              Thanks for the advice.
              Keith
