Alright, so i had to remove my front passenger shock, like completely, and when I went to remove the bolt on the top, it sheared the top of the shaft off, this equals fail. like all brand new parts, I should have a new one 4 tuesday, for now, an old stock shock, with the eibach spring, anyone else ever have to deal with this?
KYB Fail.
Re: KYB Fail.
Did you compress the spring before taking the top nut off? When I had KYB's I took them apart about 4 times with no problems.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: KYB Fail.
yessir you could jiggle the spring it was so compressed, whatever though, I called summit and they are sending me a replacement that should be here on tuesday, I'll have to take a picture of the aftermath, but for now its 3 kyb's and a decarbon, I'll try to not drive a ton i guess.
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
