piston rings - FirebirdV6.com/CamaroV6.com Message Board
piston rings
  • piston rings
    How much for piston rings if I do it myself?
    Where to get em?
    What else will I need?
    Any professional jobs I should get done while its all apart?
    Any other instructions/help?
    thanks
    Re: piston rings
    ok, i can answer about half your questions. i have no idea how much it'll cost, or where to get them. the motor has to be out of the car to change them though, at least im pretty sure becuase our engine bay is so cramped. anyway, i'll your'll need is ring plyer's, they go the oppsite way normal plyers do. like when you squeeze the handle on a normal pair of plyers, the teeth get closer together. the ring plyer teeth go away from each other. anyway, your'll need a ring compressor thing, all it does is hold all the rings compressed so you can side the piston in the sleeve. you only put the ring compressor on just anough to cover the rings, then as you push the piston in ( handle of a hammer is what i use ) you loosen and slowly take off the ring compressor. now i know the rings have to be staggered, but i dont know the exact degree apart from each other. its not hard to do, i think its fun. you kinda need two people though, one to push in the piston, and one to line up the connecting rod to the crank.
    sorry if thats a little confusing, i'll try to be more clear if you get lost somewhere.
      Re: piston rings
      I understood 100% thanks!
      I helped put my friends pistons in last night, so that helps me overcome the fear of f'king something up.
      What all would I have to take off to change piston rings? heads, timing components, etc?
        Re: piston rings
        Basically your going to be down to a block and crank.
          Re: piston rings
          yeah, thats what I thought.
          just didnt want to have to rebuild/get new parts when I'm just changing piston rings.
          time for more research but you all are a great help!
            Re: piston rings
            Its a must that you have the cylinders honed before you install new rings otherwise you'll have a smoke bomb on your hands. Also, if you buy aftermarket rings, most likely they will have to be file fit otherwise the ends will butt together and you'll pop the top of your piston off.
            <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
              Re: piston rings
              Be cautious here because you are potentially about to open a pandora's box! And the real question you need to ask yourself is what is the end result that you want when you have it all put back together? Because depending on what you want as an end result will determine how you proceed here.
              If you just want to get it running and don't really care about the overall quality of the engine you can have the cylinders honed (by a shop or yourself) and throw everything back together. But I've seen this done before on high mileage engines where only the rings were replaced (or even when rebuilt heads were put on) and the resulting improvement in the pressures at the top end of the engine leads to a more rapid degredation or even failure of the bottom end (crank/con rod bearings). Now I haven't seen this happen yet on a 3800 engine, but have on others.
              Chances are if you send your block to the machine shop to get a cylinder hone, expect them to start finding other things worn in the engine. For example, what are you going to do if they tell you that the honing will not remove all the cylinder wall scoring without boring to the next oversize? Are you going to live with some scoring or are you going to bore oversize with new pistons etc...? You might find yourself in a rebuilding situation quicker than you think.
              Make sure that you actually need those rings replaced. (I see in your other thread that you're trying to do that)
                Re: piston rings
                well CRAP! I knew the problem was gonna be piston rings.
                I put oil in just 1 cylinder..the original compression was 100psi
                after the oil it went up to 150psi. I dont think I need to check the other cylinders, do I?
                CDNFB: I dont think my cylinders are scored, but what do I know, I'm a rookie. SO, you told me that if I just want to get it running then just throw it all back together and do a cylinder hone. BUT, you didnt say what to do if I want quality! What do I have to do if I want quality and I really want to race my engine? My engine WAS running GOOD times, I promise, it was fast...
                wickedsix/lance: can you tell me more about file fitting the rings? I've never seen that done before. Usually I see people just put the rings on then hammer the piston back into the cylinder.
                  Re: piston rings
                  ok, well... I'm stupid for thinking I dont need to check the other cylinders.
                  Cause a compression test will tell you more than just bad rings/head gasket.
                    Re: piston rings
                    would putting oil in the cylinders also seal the head gasket?
                    I'm kinda having trouble finding rings. What all will need to be changed during a ring swap?
                      Re: piston rings
                      Well, for a set of chrome-moly piston rings, it ran me $130. I bought them last week at a performance shop.
                      And it's a very easy install of them once the engine's out.
                        Re: piston rings
                        Well, if you going for a quality job and/or your going to bump the HP up (either built in or bolt on) you gotta do the job right. To do that you have to ask yourself about the mission you want this engine to fulfill. What target HP you want, how hard your going to run it, how reliable, etc.. Without doing this you can easily overbuild or underbuild your engine, which always results in dissappointment and $$$$$$ wasted.
                        Also you have to understand the present condition of everything in your engine. If your target is exceptional reliability or extreme HP you will have to do a complete teardown and inspection. At the other end of things, inservice tolerances might be acceptable for mild gains in HP thus complete teardown might not be required.
                        You also have to factor in special requirements for power adders. An example of this is lower compression and forged pistons for FI engines (depending on HP and boost levels).
                        With your engines mission defined and a complete understanding of your engine's present condition, you can then ask intellegent questions and determine what is really required or not.
                        Right now (while the engine is out) is the time to build the core engine to meet your future requirements. By core engine I mean the pistons, rings, connecting rods, crank, and block. Right now you might not have all the cash to do everything you want to, so focus on the core because everything else can bought and bolted on or put in later when you have the cash. You have to consider a properly built core as the most important supporting mod for all those other mods that you intend to do to get major HP gains.
                        DZ
                          Re: piston rings
                          it runs a 13.5 sec in the 1/4 N/A no bull
                            Re: piston rings
                            So what you're saying is that your car ran in the 13s (before this latest adventure)??
                            I seems to me that you're not the one who built it to do that.
                            Perhaps this is a good example of using an engine core that was not prepared to do the job.
                            DZ
                              Re: piston rings
                              no, I bought the car brand new in 2001, its a 2002
                              I did all my own work, like installing my 4.10s
                              But when I flushed my coolant I had a leak, all the coolant drained..
                              The car overheated several times, so thats why the head gasket and piston rings blew. Im such a Tard
