Does anyone know where I can find building plane/blueprints or something like that to build a stealth box?
Want to build a stealth box.
Re: Want to build a stealth box.
Its for the passenger side, but it's the same thing. And don't be afraid to work with fiberglass..... it's actually pretty darn forgiving.
http://www.fbodyaudio.com/articlevie...tealthbox.tech
I dont want to mess with fiberglassing, I want to build one like this. http://www.ls1tech.com/forums/attach...chmentid=63870
http://www.ls1tech.com/forums/attach...chmentid=63872
I built a few stealth boxes similar to that out of wood. Interesting how that person built theirs...I built mine with lots of complex angles and miter cuts...it took forever. I built mine one piece at a time, starting with the baffle (the front) first, then the bottom then I went from there. Theres really no blueprints available to build something like this, its all trial and error. I'll try to find some pics of the ones I built. Good luck2006 Tiburon
I was going to use a 10" sub but I already had a dual voice coil 8" sub laying around so I just used that. it actually sounded nice...I wasn't going to enter a bass competition or anything but lets just say it sounded way better than those wimpy Monsoon subs.
I used poster board to make the template. I just kept trimming a little here and there till I got the shape I wanted. I still have a couple fronts already cut out laying around. (had ideas of building a bunch of them to sell but it takes way to much time lol). If you want,I can trace one of them onto a piece of paper and mail it to you. email me: tiburon0676@yahoo.com2006 Tiburon
Naa, I'll look at it tomorrow and try it out myself. All I got right now is wally world Lightning Audio 10in sub, it actually sounds good and gets loud enough for me, I'v been told told that they dont last very long but I'v had it since September. I cant stand having a sub box taking up more than half of the trunk anymore lol.Last edited by Josh_101; 05-08-2006, 03:37 AM.
I made my own from MDF, here's my basic steps:
My box had 7 pieces - bottom, front, back, left, right, and 2 triangular top pieces. Only a few right angles in the whole thing. Sub is a 10" a/d/s aluminum.
1. Make a mock-up with cardboard. Then make a second cardboard mockup using the pieces of the first with the clean edges that your first one won't have. Make sure the second mockup fits.
2. Cut the MDF pieces out. Due to the messed up angles, you'll have to do some sanding or cut some pieces a bit smaller to get to the same outside dimensions of the cardboard piece. Super tight isn't critical, I had up to 1/4" gaps in spots. They will be taken care of later. Honest!
3. Tape the wood pieces together inside the compartment and make sure they fit. Once you glue, no going back.
4. Cut the hole for the sub. Make sure you have the clearance around the magnet etc when the box is together.
5. Glue it together. Play it safe, a panel or two at a time, getting the positioning right. Use tape or whatever it takes to hold things in position.
Remember those big gaps you thought would never be sealed? Here's what I used to get rid of them. I glued my box with a 2-part epoxy resin filled with Cab-O-Sil (sometimes seen as Cabosil). Cab-O-Sil is fumed silica, and a little Cab-O-Sil can do a lot of thickening. I made a thicker paste which was just about self-supporting. Slapped it into the gaps real well to fill them in, and the stuff stay put until cure. Any air bubbles or spots where it did sag a bit I refilled with another batch. Be messy, overfill, don't worry. Concentrate on getting the MDF in the right place and filling those gaps.
You can get good 2-part epoxies and Cab-O-Sil at places like surfboard supply shops and other small composites suppliers on the web. Let me know if you have questions on any of this stuff, I work with it all the time.
6. Sand off the excess resin. A dremel with a sanding drum works well, and smaller burrs will do inside corners well. Might want to wear a dust mask if you dremel since you'll be shooting powder all over.
7. Finish with carpet or whatver you want to wrap it with. I cut the carpet short of the sub hole so the sub doesn't sit on the fabric and leak air (put sub on hole and trace the border)
8. Drill a hole just big enough to get the speaker cable into
9. Install the sub. I used some silicone caulking at the speaker wire hole to seal it better, and the foam weatherstrip on the sub hole to seal the face.
10. Thump away!
BTW, my stealth box is held in with velcro. a nice patch of the industrial stuff on the bottom of the box, matching patch on the bottom of the compartment, and it hasn't budged in 5 years of autocross, road racing, potholed roads, you name it.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
Done!! We got it built and installed! It sounds a little quieter than before, is this normal for a box thats a little smaller and not sitting in the middle of the trunk? Other than that, it sounds good, a little boomy'r than before in the higher bass frenquencies, which is good cause I listen to alot of rock music.
Heres some pics. The quality is kinda crappy, some dirtbag stolled my camera so now I'm using my dad's. GRRRR theives piss me off!
http://i1.tinypic.com/zjch7c.jpg
http://i2.tinypic.com/zjchur.jpg
http://i3.tinypic.com/zjcidi.jpg
http://i3.tinypic.com/zjcklz.jpg
Yah, for the small sealed box getting no leaks at all is critical, otherwise you lose a lot of efficiency.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
Go Sabres!
