i went to zzp and could find the alt rewire kit did they discontin u it
alt rewire kit
alt rewire kit
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
2001 Pewter Firebird Y87, M5
Go Sabres!
Re: alt rewire kit
cool thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Re: alt rewire kit
would this mod work well on a 3.4?
and is this part of the BIG 3 wire mods? or is that a separate mod?
hey i also saw this on their website, https://www.zzperformance.com/grand_...=517&catid=107
improved voltage to the alternator for 15 bux, would this work on our cars? and is it a good idea?Last edited by tkoforpresident; 11-29-2007, 06:46 AM.
Re: alt rewire kit
Yes, this is once wire of the "big 3"
The voltage booster is a diode that drops the voltage of the sensor wire going into the alt- it fakes the alt into thinking that the system voltage is lower than it actually is, so the alt ups the voltage to compensate. Most people who do the big 3 won't need to mess with anything like this.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
Go Sabres!
Re: alt rewire kit
good cuz i just realize it won't work for my 93 =)
is the alt rewire kit really as easy as it sounds?
Re: alt rewire kit
Originally posted by tkoforpresidentpics? write up?
"4AWG flexible cable replaces the much longer current choking 8AWG factory"
And then just do what it says on the website...
"The stock wire goes from the alternator to the starter with a 10’ wire and then from there to the battery through another wire, then from the battery to the top of the under hood fuse box. Our alternator rewire goes from the back of the alternator to the power connector on the under hood fuse box"1999 Camaro Z/28
1973 Firebird Formula
Re: alt rewire kit
yes it is one wire from zzp, I was the test vehicle for it. :) I live 10 minutes from them.
and yes, part of the "big 3" is upgrading this wire
Re: alt rewire kit
Originally posted by 97rs4lifeyes it is one wire from zzp, I was the test vehicle for it. :) I live 10 minutes from them.
im guessing this is the easiest of the big 3 right?
the other two are more involved aren't they?
Re: alt rewire kit
All 3 are easy..Drivetrain Moderator - "There are no stupid questions, only stupid people!"
Go Sabres!
