my starter grinds - FirebirdV6.com/CamaroV6.com Message Board
my starter grinds
  • my starter grinds
    when i go to start the car, the starter grinds for about a half second after the car is started.
    does it every time... is it really that bad for it?
    I mean, my 69 camaro has a stock starter that is turing 12.5:1 compression for 30 seconds at a time... and it still works perfectly
    Having trouble engaging the flywheel maybe? Yeah I would get that taken care of asap.
    1999 Firebird
      you most likely need a new starter. My stock starter did the same exact thing you expalined..it buzzed and once my car heated up real well and you shut it off and went to go start it again it wouldnt turn over...or even click like the battery was dead but you still had power for everything. I just got a new starter...it was 100$ for our cars and replaced the old one. Its a self do job its pretty easy. Ever since i put a brand new starter in it its ran great and no more problems. Hope this helps
      Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
        no, it grinds after the car has started.
          it doesnt buzz like mine does
            Solenoid is going - not releasing properly. Easy to change.
            95Camaro3.4T5Conv Red/White*SLP Bilsteins*BMR Tower Brace*CAI*NiehoffIgn*NGK PlatPlugs*DelcoHiPerfWires*FlowmasterCatback*RedDe vilReso(no cat)* DynoMax Muffler*B & M Shifter*Eurolite Lamps*Yokohama Avid 235/55/16*GM 3.73s*Auburn LSD*Sirius*All DONE!
              The contacts are burned and pitted on your solenoid. Whats happening is each time you start your car they kinda welding them selfs together. Better get if fixed fast before the really stick together and dont let loose.
                i took apart my bad starter, put it back together, took it to oreillys and it grinded bad
                  what do you mean, you took it to oreillys and it grined bad
                    i mean, I took it off the car, took it apart, put it back together, took it to Oreillys, hooked it up, and it was grinding bad.
                      so, what is the problem?
                      the solenoid is going bad, and it isnt going back in fast enough?
                        yes, its getting stuck when it makes contact.
                          ok, maby i can take it off, and clean it up... maby it will work
                            imo just buy a used one, seems like a few are floating around for cheap.
                              im probably not going to do anything, it has been doing it for like 3 months (since i got it) and it still hasnt gone bad
