Normal idle RPM? - FirebirdV6.com/CamaroV6.com Message Board
Normal idle RPM?
  • Normal idle RPM?
    I've searched, but only found out that it depends on the temperature. I'm not sure if I should be concerned or not...
    I had a pretty bad coolant leak/issue, so my dad's friend fixed it. He replaced the water pump, radiator, and intake gasket. I got my car scanned when the SES light came out about a month ago, and it was for the O2 sensor after the cat. So I bought a new sensor. He said that when he scanned the car, it was for high-speed idle or something like that. So I have an O2 sensor sitting on the seat, I'm going to wait a few days to see if that code comes back. Anyways, after picking up the car tonight, I've noticed my idle RPM is a bit higher than it was before. It was around 1200 at idle, when it used to be around 700 before. This messed up my shifting a bit, and I spun leaving his place because I didn't need to give it as much gas as before. I also notice, at least I think, that my gas pedal is closer to the floor than it used to be. When I got home (about a 10 minute drive), the idle RPM had dropped down to about 1000, but that was still higher than what I used to see. Do you think I have a vacuum leak? If so, is it probably at the intake gasket?
    Thanks for any input, I'll drive the car more tomorrow since I hate driving at night when the roads are wet.
    <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
    Re: Normal idle RPM?
    My idle is at 1k so the only reason I can think of your idle changing is vaccum leak. I mean it could be injectors clogged, spark plugs, anything but without looking I would guess vaccum. But my RPM's usually idle at 1k exactly.
      idle is usually supposed to be 1000k and under. Unless its a really cold engine.
        i believe at cold I idle around 1500 and the lowest mine ever goes is about 800 or 900... I'm usually, well always at 1k
          that seems high, or maybe I am...
          I dunno I think 1000 is pretty high
          Can't remember exactly what mine is but I thought it was under 700, like 650
          (and after replacing the FPR the needle looks glued in place at idle too, I'm happy about that and the fast starts, now if it wasnt such a boat)
          is it even possible to adjust the idle on these manually?
            Re: that seems high, or maybe I am...
            FPR helped out the idle and consistancy? How hard of a thing is that to install? And how much does that cost? Cuz my idel is kinda rough and sounds just what i need replaced.
              http://forum.camarov6.com/showthread.php?t=79714
                I don't think this is the kind of part that is usually associated with idle problems. If you have a bad one causing a hard start it may be worth replacing but other than that no... they go bad and cause fuel to leak into the intake manifold thru the vac line, which causes the car to flood for a while after its shut off, and I think the reason it surged a little bit at idle for me. either that or cleaning the injector tips did it, or a combination of the two, I dunno. My idle was pretty consistant before doing this so I doubt this is the miracle fix you are looking for
                  here is a stock 97 idle table for an example of roughly what a stock car should idle at. Difference in years is usually no more than 50rpms in each range that I have seen
                  http://www.bowtiev6.com/
                    Mine is a 5spd as well, if that makes any difference.
                      ok i varified it for you. just for you guys i went out and started the beast up. its 1500 cold and 950-1000 hot (rpm) for my 98 v6
                        ...x2 here
                          Ok I confirmed mine is under 700... somewhere between 650-700, depending on what angle you look at it
                          3800 from the year 2000
                          is that *too* low?
                            i mean if its not about to stall or running real rough, well IF IT AINT BROKE DONT FIX IT. lol if it runs like crap then somethings wrong.
                              I also got an SES code for idle RPM too high. Turns out when the guy who worked on my car put the throttle cable back on, it wasn't on correct. So we fixed it and idle is back to normal. Now I just gotta clear these codes to see if I need this O2 sensor or not...
                                Had to be evacuated again due to fire
                                Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
                              • RPDRed6
                                For Sale: 2001 Chevrolet Camaro project.
                                by RPDRed6
                                Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...
                                No start problem
                                So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...
